The answer is that the set has a code that repairmen plug enter in and it gives you an option to adjust 'ghosts'. Not sure what code is but it is available through other sites.The answer is that the set has a code that repairmen plug enter in and it gives you an option to adjust 'ghosts'. Not sure what code is but it is available through other sites.
You can't post conmments that contain an email address.
This is normally caused by bad grounds in the cabling. Check or replace the cable. Also check your manuals and be sure the cables don't have to be terminated How to Fix LCD Monitor Ghost images
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able work your way through the problem
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
you have dust on your ccd... this is really bad... its something i can't recommend trying to fix at home... its so easy to get more dust in there... so if you really like the camera take it to a repair shop?
i had a dust shadow on a camera i really liked ... it was on the top half of the image and always looked terrible... so i started taking pictures with camera UPSIDE DOWN ... you could hardly ever see the shadows on the darker background....
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Replacing the "light engine" fixed the problem. The technician said that there was a felt-like lining in the light engine to prevent undesirable reflections from the insides of the light-engine hardware, and that it becomes detached and blocks an edge of the picture.
We had a dark line along the right-hand side that was like looking at that portion of the picture through a 1" strip of very dark glass.
Because the DLP is new technology, we purchased an extended warranty from Best Buy (actually, their Magnolia subsidiary) which covered it.
The new light engine was slightly different physically, and the technician had a hard time getting the picture centered and aligned on the screen after installing the new one. In fact, he gave up on the first one and fetched a second one from his truck. He also had problems with the second one, but finally got everything aligned.
coolant on picture tube need to be replaced
hard job to do with not enough experience and knowledge , a tech can fixed 1 to 2 hour job with parts around 300.00 or less dependig on the tech.
