SOURCE: Need owners manual for 1995 Coleman/Fleetwood Niagara Pop Up Cam
This is a link to a pdf for the '95 manual from the Coleman site
Coleman®Camping Trailers by Fleetwood Owners Manual
http://www.colemantrailers.com/uploads/91731235052535.pdf
SOURCE: I have a '93 coleman, cedar tent trailer with a
I have the same issue. It looks as though the rivets broke off. I have yet to reattach the slide mechanism. Normally the slide mechanism is stopped by a peice of emtal about 1./2 the way down the slide. Either new rivets or some flush head screws might sole your issue.
Ha, right in my wheel house! Correct there are two sets of rollers on each side of the bed slide out. The second roller (one closest to the interior of the trailer) stops at about midpoint on the roller. There typically is a small square piece of metal that is pop riveted to the inside of the track, located about where the middle of the bed is. You should see that the aluminum frame work for the bed slide out rivets together at the center of the bed, this is your working area. I would suggest removing all of the screws on the underside of the slide. You will also need to drill out the rivets on the center support and where the two parts of the bed framework meet. Pull the outer portion of the slide frame out and that should reveal your problem area. You will need to re rivet this stopping piece so the slide out will stop. If this piece is missing, you can fabricate a small square piece to replace it. If you have any other questions about tent trailers, let me know. I have stripped them down to the frame and gutted them only to rebuild them. Hope this helps. D
SOURCE: need 2000 owners manual for coleman niagra pop-up camper
Try this link
http://www.popupportal.com/index.php?action=media;sa=item;in=2985
