I've had good luck with that same 2wire router, but Att is right, the ethernet & internet lights should stay on. Have you tried moving the ethernet connector to a different port on the router? If they're going out, some component inside is failing, but it could be specific to that one port, and you may be able to use another without a problem. (Just a thought.)
You can contact 2wire support directly
from here, if you choose.
And there's a full user's guide with some troubleshooting options and diagnostic tools available (to some subscribers)
here.
But it sounds like it may be time for a new router...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Try ipconfig to check if and modem is detected then further troubleshooting can be done by connecting the modem with hardwire
