Contributor
- Posted on Aug 18, 2010
Re: Lawnmower sat up for a season would not crank...
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
could have stuck valve? does it have good compression?
if the mower sat with gas in carb.alll winter clean and rebuild carb.
