Question about Sharp XR-10SL DLP Projector
I replaced the lamp, then the projector is not switching, but the standby and lamp indicator are red, no button is working. how can i reset?
    New Friend:
  • 89 Answers
Check if you need to reset the lamp life time counter clock after changing the lamp. Check the manual for details.
Posted on Aug 10, 2010
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
PG-MP60X - Power light is red, lamp light is red, projector not working. How I can fixed that ? thank you
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 04, 2014 | Sharp PG-M60X Multimedia Projector
I replaced the projector lamp and still no light what am i missing. all i get is a solid red lamp indicator and a orange power indicator.
hi,
Did you reset the lamp hour after replacing the lamp. If not do the following for the same and try again. Also check is the lamp inserted is correct or not. Also check the lamp cover is properly closed or not.
press the "Help" button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the LAMP indicator (red light )goes out.
ok
Feb 10, 2011 | NEC VT465 Multimedia Projector
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Jan 24, 2011 | Sharp XR-10X Multimedia Projector
My NEC MT1060R will not turn on and the status indicator is flashing red four times, before and after I changed out the lamp.
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual. (It could have been the on button, can't remember now)
Good luck
Nov 30, 2010 | NEC MT860, MT1060, 1060R and 1065...
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    I have a sharp projector RX30X the stand by light still red it doesn't blink and the device doesn't work what's wrong?
    Have a nice day!
    Jerry
    Lampdeng Limited
    Jun 02, 2010 | Sharp REPLACEMENT LAMP FOR XR30X/30S/40X...
    Resetting the lamp timer to zero
    some times the lamp cover switch is broken or not setby the cover ,this wil shut off power on button
    May 27, 2010 | Sharp XVZ200 Multimedia Projector
    Reset Lamp Hours Timer
    This works on a couple different Toshiba models -- might work on yours...
    Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
    Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
    Sharp XR-10SL DLP Projector Logo
    151 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    amir hamza
    amir hamza
    Tareq Bin Mostaq...
    Tareq Bin Mostaq...
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
