Question about eMachines EZ1601-01 All-in-one PC 18.5' Widescreen Intel Atom N270 1GB DDR2 160GB Intel GMA... PC Desktop
" and @ keys are reversed how do I fix this - eMachines EZ1601-01 All-in-one PC 18.5' Widescreen Intel Atom N270 1GB DDR2 160GB Intel GMA... PC Desktop
Renault Midlum fault code defect 92 how do you fix it
This is a key error code so could be immobiliser problem, the reverse lights run off the same fuse as the immobiliser check the reverse lights.
Apr 24, 2016 | Renault Cars & Trucks
How do you stop your trunk from opening when you put your car in reverse?
You have a short between the trunk motor and the reverse lights. Follow the harness from the trunk latch to to reverse lights. Open the harness there and start looking.
Jan 10, 2015 | 2003 Mercury Grand Marquis
Weedeater lawn mower won't go forward or reverse
Try the friction wheel, you guys over think things. Use a snapper wheel, then use your original friction band, you'll have to modify the snapper wheel a bit but it will fix your problem
May 26, 2013 | Garden
Both reverse lights are not getting power, i cannot locate the fuse. I know where the box's are located, one under the dash, the other two under the hood, non are labeled for the reverse lights. s
Put the car into reverse turn on the power key get the volt meter and test the wires if you have voltage at the lights on the rear and trace the wires back to the gearbox you should be able to fix it this way.
Jun 25, 2012 | Infiniti QX4 Cars & Trucks
Hi my scooter will drive in reverse on its own at all kinds of speeds if u leave the key on and is slow in forward only it will only stop in reverse if you turn of key or disconnect the forward or reverse...
Hi tandseaster,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. I can almost tell you what kind of scooter you have. In the future give as much info about the scooter as possible.
Your problem is the throttle pot or somtime called the engager.
You can do one of two things. 1. Open the faceplate to your tiller. look for a lock nut on the throttle pot. loosen it, on the bottom of the pot is a slot for a flat tip screwdriver. Take the key out before you start this procedure. You can turn the screw slot on the pot a little at a time, one way then the other. Turn the key back on, turn the speed pot to lowest speed so the scooter won't take off on you. Once you align the throttle pot to neutral tighten the lock nut. The easiest way to fix your problem is:
2. Replace the throttle pot.
Your problem will be fixed.
Good Luck
Tim
May 02, 2011 | Health & Beauty
Can't turn key all the way to get the key out of the ignition
just give the shifter a little tap or **** in the downard position to key the key to turn, the problem is with the shifter linkage , it gets loose and sloppy , in order to fix the problem you would have to tighten evry pivot point on the linkage below the shifter itself , i have the same problem , mine will also not go into reverse unless the shofter in in between the parking and reverse positions , I must listen ( or feel ) for the engament to kick in
Apr 20, 2011 | 2001 Oldsmobile Bravada
My KM-2035 appeared error call service C6000 on my copier.
on the nunber keys, key in 10871087 the display should blink then enter 163 then;
1. Press the start key. The screen for executing is displayed.
2. Select the EXECUTE using the up/down cursor keys. The selected item is displayed in reverse.
3. Press the start key. The fixing problem data is initialized.
Jan 16, 2011 | Kyocera Mita Office Equipment & Supplies
The stick shift knob appears to be not working anymore. I am able to drive and reverse the car but cannot take the keys out of the car. Is it still OK to drive the car?
Your problem is most likely in the key itself
You won't hurt the car driving it, but you will need a good shop to fix your key issue
Mar 11, 2010 | 2004 Nissan Quest
My reverse light stays on
It seems the reverse light switch which is fitted on the gear box has sized to 'on' position, the remedy is to replace the switch.
To male sure its the switch, locate it and remove the connection to the switch thn check it out if the reverse light stays 'on' whn you turn the igntion 'on'.
May 09, 2009 | 1996 Ford F250 Crew Cab
eMachines EZ1601-01 All-in-one PC 18.5' Widescreen Intel Atom N270 1GB DDR2 160GB Intel GMA...  PC Desktop Logo
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
