Lexmark X5470 All-In-One InkJet Printer Logo
Posted on Apr 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant retrieve faxes in lexmark x5470
How do i print fax jobs in memory?
Anand Kumar
Level 3:
Genius:
  • Master 2,035 Answers
  • Posted on May 02, 2008
Anand Kumar
Master
Level 3:
Genius:
Answers
2035
Questions
Helped
852198
Points
5335
Try this remove the cartridges and replace it back and turn on the printer this will print all the faxes stored.
How do i print a fax stored in lexmark x5495 if a fax is sent and does not print out, is it saved anywhere for me to retrieve
When an incoming fax is stored temporarily in the printer's memory, chances are, one of your cartridges has low ink level. To retrieve stored faxes, current state of printer must be on the instance when the fax is temporarily sent to printer's memory. Replace your low-ink cartridge without navigating away from the Fax function. Once you have replaced the cartridge, press Ok button to continue printing the fax.
Lexmark x5470 the machine received faxes but does not print them. saying "fax jobs in memory"... how do i print them?!?!
It could be because one of your cartridges has low ink level, thus printer is not able to continue printing the fax message. Open the printer cover and replace your cartridges (without navigating away from the fax mode). Once cartridge/s has been replaced, just hit the Check mark to print the fax message.
I cant receive fax. it has some in the memory.
if there are a message like empty cartriage or low cartridge that means
the printer want new cartridge for print fax, when it print another document and also print reports without trouble.
1helpful
2answers
My printer is in a paused status and i cant unpauseeeit
Hi did u tried to restart the printer if still have the prob please double click on the printer icon comes when u issue a command to the printer check if it shows if there is an error try to cancel the print job which has error and restart the print job if still dosent go on printing just go to controll pannel >fax and printer devices> right click on the lexmark printer icon and remove it and then adda printer put the provided cd with lexmar and reinstall it it should be ok ....
2helpful
2answers
Print faxes in memory on a Lexmark X5470 All-in-One
I solved my problem by powering off, which I knew would lose the faxes in memory. However, I decided to have the faxes re-sent. As soon as I get time, I will address this issue with Lexmark. It seems incomprehensible to me that Lexmark does not provide instructions on how to do this.
Thank you for your interest. This simple question does not warrant a team to figure out--it is a manufacturer's responsibility.
Need fax out of memory
There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Faxes
hmmm..with faxes in memory, that message means emptying out the memory, not the print cartridges..poor use of the word on Lexmarks' part.
do you have their print manager installed? if not, you can most likely find it through this link
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
