Does the flash open?
Open the flash and try alcohol or purell hand sanitizer on the hinges and release mechanism. Let it soak in and work it in by moving the flash hood repeatedly up and down
Also check the canon eos 350d service manual from below link:
http://goo.gl/rnauJZ
it will save you money
thanks
SOURCE: Canon EOS 350D CF memory card won't go into slot
It sounds like you have some bent pins in the card slot. Take it to a reputable camera repair and they can look and tell you for sure.
SOURCE: Canon EOS 350D Driver Windows 7
You need to change the camera's USB connection mode from "PC" to "Print/PTP" in camera setting menu. After that it should be recognized by Windows 7 without drivers.
SOURCE: Error 5 on Canon eos 350D
Well first of all you can try a full reset, Pull both batteries out -the normal one, and the date/time one. If your camera is older (>2 yrs), it may be time to replace that battery..... anyway Put a new one in, and then put in the freshly-charged main battery, that might clear the error. If further you have the same problem then something is causing the flash to stick. Press the button and pull gently on the flash. Post comments for more help or information needed.....
Good Luck!!
Thanks for using FixYa!!
