Ok cammy there are several ways to solve this puzzle of yours.... first off here is a link that will explain the multiple beeps from your computer as follows!
http://www.d-a-l.com/help/general-hardware-issues/12347-beep-code-list.html
and being that your computer beeps 6 times could possibly mean that
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
Generally, six beeps means a keyboard controller error. Unplug and replug
your keyboard when computer is off. If that doesn't work, you may have a bad
controller on the motherboard
Assuming that you didn't do a fresh install of windows, Do this:
When the blue screen with the HP Invent logo
appears, press the F10 key on the keyboard. (You
have only a few seconds to press the F10 key
before the normal startup process continue
Then Select Full System Recovery (which will erase whatever you had in computer such as personal files, etc). Pretty much your system will be back as Factory Image
Thanks
DiegoTech
