Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on Advanced then NAT settings. Then you can change those settings. Let me know if you need further assistance. Thanks for using FixYa.
Click the Virtual Server link near the left of the page.You should now see a new menu. In this new menu, click PPPoE/DHCP/Static.
PSN requires you to forward the following ports:TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
Go ahead and enter the settings shown above into thePPPoE/DHCP/Static Configuration menu.
When you're finished, click Submit near the bottom of the screen to save your changes.
And that's it! You're done!
