Raise the top cover of the product.
Figure 5: Raise the cover
Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Figure 6: Remove the tape1 - Copper-colored contacts2 - Plastic tape with pink pull tab (must be removed before installing)3 - Ink nozzles under tape
CAUTION:
Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure,how do you place cartrige in printer - c00442147.giftrical connections.
Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
Slide the tri-color cartridge into the left slot.
Slide the black or photo cartridghow do you place cartrige in printer - c00830211.jpgght slot.
Figure 7: Insert the cartridge
Close the cartridge door.
Figure 8: Close the cartridge door
Optimum Geek Support provides the Canon Printer Support, Canon Pixma Support Number 1800-303-2439, software installation, software upgrade, cartridge jam, paper jam issues and much more. Canon Pixma Printer Support USA Canon Printer Support
Try to clean cartrige and cartrige carrier conector place with soft erager.Then put cartrige into cartrige holder then gentaly push top of the cartrige sothat a `cat' sound happend, then turn on printer.
I think you will relive
Thank you
Jast bring the cartrige holder on cartrige changing place and wep the connector (which are situated in the front wall on the carier) with the soft tissue paper. and install the new cartrige.
I thing it remain work again.
Thank you
well printers calculate ink, with printing jobs. If you exchange cartriges in the middle of these ( ex:you exchange cartriges about after 100 print jobs and the cartriges is 500 top) the printer dont know excatly the ink level, so gives these error on calculation, not exact ink level. so you need to take out and place again to reset cartridge counter.
A lot of printer manufactures place a small chip on the ink cartridge. Combined with the printer software it knows you re-filled the cartridge. This forces you to buy new ink. A work around that works with some printers. Keep you're old ink cartridges. Replace with new and when it empties replace with you're re-filled ink cartridge. Store you're old re-filled cartridges in a dry cool place when not in use. With HP printers users keep three cartridges.
The message you are getting may be due to the following reasons :
1) Cause : One or more ink cartridges missing.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place.
2) Cause : One or more of the ink cartriges are not installed or are installed incorrectly.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place. If the problem persists, clean the copper-colored contacts of the ink cartriges.
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige. 2. removed all the paper from the tray and noticed that one of the pages was a little jammed. 3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message. 4. I then put the black cartrige back in the the printer and restarted the printer. 5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Remove the cartridge, take a flashlight and check the right side inside the printer for a RED LED (in the place where the cartidge stays). Take a tape and patch that LED. That's all ! Enjoy
Did you try the clean head function and examinte the test result. Sometimes the inks will stick on the connnection pad inside the printer. If this happens, you have to take out the cartrige and clean the contacts on the pcb. Try other ink cartrige and see if the problems stick to one ink cartrige or caused by hardware failure on printer.
