Minolta Vectis 2000 APS APS Point and Shoot Camera Logo
Anonymous Posted on Aug 08, 2010
Minlota Vectis 2000- I want to open the film door without battery power. Is there an emergency release?
  • Anonymous Aug 08, 2010
    Thanks for the prompt answer, i think it just needs a battery and it may be empty already but before I get rid of it I wanted to check but didn't want to by a new battery for a camera I was not keeping. Very helpful info though, I will stop driving myself crazy looking for what doesn't exist! Thanks Again
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Aug 08, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
959186
Points
10121
In short, no. The camera must be dismantled. If the film hasn't rewound, then if you wish to save your images you must dismantle it in total darkness: not easy! As the camera is usually a write-off anyway I just slowly crush APS cameras in a vice in my darkroom until they pop open enough for me to extract the film.
If the camera is faulty and not just in need of a fresh battery, then after recovering your film just chuck the camera away; it's not repairable and it definitely isn't collectable. APS was a poorly-engineered system from the start and 35mm has outlasted it largely because APS cameras were generally highly fault-prone and unreliable. It also didn't help that the image quality was worse than on 35mm because of the smaller negatives.
It's not all bad news: 35mm cameras of most types are now mostly near worthless and so commonly available for free on FreeCycle and Freegle as are APS cameras if you really want another.
Hopefully you will just need a fresh battery, but either way I hope that you manage to recover your film successfully.
Testimonial: "Thanks for the answer, saved me the trouble of pulling my hair out looking!"
  • Anonymous Aug 13, 2010
    Thanks for the feedback, happy to have been of assistance.
    I'd be very grateful if you'd take a moment to rate my original reply to you.
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
Feb 21, 2024 • Photography
APS film chamber stuck shut. Door won't open when film chamber release button is pressed
Sorry to hear about this issue. If you have a change bag, I would put a few jewelers screwdrivers in it then put the camera in it. With the bag closed up I would attempt to forcibly open the back. With the camera in the bag there is not any chance to expose the film. After the film is removed wind it back into the cartridge. Now send it off for developing.
Good luck,
Cordially,
I reset my liftmaster/chaimberlain keypad (976LM) and now can't access garage. Is there a default code? No other access into garage (new owner to this house).
Make sure the battery in the keypad is good. You cannot reset the keypad without access to the opener. You will have to find a way into the garage.
A door technician uses a special tool to pull the emergency release after drilling a small hole in the door. The door can then be lifted without damaging anything. A keyed manual release assembly is then installed in the hole to be used if there are problems in the future like a power outage or malfunction like you have now.
Where and how do you insert film on a minolta vectis 2000 camera
Essentially, you probably don't as APS film is no longer made and is getting difficult to get processed if you do get some old stock.
But like on all APS cameras, there's a lock on one end of the camera and usually you turn it to open a small door on the bottom of the camera. The APS film cassette gets pushed into the compartment and when you close the door and the camera *should* wind the film ready for shooting and lock the door so that you cannot open it until the film is rewound. The cameras are entirely battery dependent and many used CR2 lithium batteries which are disproportionately expensive and hard to find except from online suppliers.
Unfortunately APS was a badly engineered system from the start, so the cameras didn't tend to last long before suffering major faults. You may wish to bear that fact in mind as those faults won't show until you load a film and any film you do find will likely cost more than you can buy another APS camera for. They're widely available for free or for about a £ or two from almost any charity shop (not from the one I work in though as I always put them straight into the recycling bin as they're a liability).
How we change film
The user manual is available here http://ca.konicaminolta.com/support/manuals/film-cameras/asp_cameras/vectis_2000/vectis_2000_e.pdf and that explains on page 17.18 and 19 epxlains how to load the film
How do I open the compartments on the camera
Which compartments?
The lid on the battery compartment next to the tripod mount flips down.
To open the film compartment, turn the camera upside down, then turn the film chamber release clockwise.
You can download a manual from http://www.butkus.org/chinon/minolta.htm
Canon elph 2 film door wont open , tried to open with door release button but wont budge.
You need the camera powered up and all the film used to activate the release mechanism for the lock to release the film door, the Elph film door will not open until all the pictures have been taken. It uses A CR2 Lithium battery
2helpful
Vectis 2000
Hi - You can download the manual from the link underlined in blue below:
Vectis 2000
See page 19:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Top Minolta Photography Experts
ZJ Limited
ZJ Limited
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
