Amana PTH123B35AJ Air Conditioner Logo
Posted on Aug 08, 2010
HOW TO PROGRAM FAN TO STAY ON, FOR AMANA AIR CONDITIONER PTH093B35AK
5 Related Answers
Anonymous
  • 725 Answers
  • Posted on Jun 12, 2008
SOURCE: Amana 5M11TA Air Conditioner Error Code
That is a power failure error code
Anonymous
  • 3 Answers
  • Posted on Jun 25, 2009
SOURCE: i have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Anonymous
  • 614 Answers
  • Posted on Jul 19, 2009
SOURCE: Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Anonymous
  • 9 Answers
  • Posted on Aug 30, 2009
SOURCE: My old Amana air conditioner will not turn on. Is
I need to know more. when you call for cooling does the indoor fan run? Does the contactor at the outdoor unit pull in? Have you looked at the fuses,breaker. If it has been very hot lately open the outdoor unit and look for a thing that looks like a large battery it should have 3 to 5 wires on it this is the run/start cap the high outdoor temp will sometimes make this fail. You can see a failed cap 85% of the time just by looking it will have a defromed top or be leaking oil. YOU DON'T WANT THIS OIL ON YOU!
Anonymous
  • 200 Answers
  • Posted on Sep 20, 2009
SOURCE: Amana air conditioner unit, model ARUF182416AA,
Looks like there is no gas in the compressor. Refill the gas.
How do I replace the fan?
Free Amana Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Amana
Products 1 - 10 of 10 - Amana Air Conditioner 18M23TB. Amana Room Air Conditioner Use And Care Manual. Pages: 0 Saves: 0. See Prices Buy or Upgrade .
Amana PTAC will cool but fan will not go up in speed
Change the thermostat wire , if not change your board.
I have a 1400 btu portable air conditioner ( AMANA ) and the fan is broken, how to replace it.
Obviously, you will have to disassemble part of the cabinet to access the fan blade. Removig the blade should not be difficult. If it's the fan motor, than that may be a challenge. However, since you did not furnish the Model Number of your AC Unit, there's not much more I can tell you, other than where to find the part(s) you'll need. Try Factory Appliance Parts http://www.appliancefactoryparts.com/airconditioners/amana/amana-motors-and-blades.html You'll definitely need the correct Model Number of your unit, to search for the part(s) you'll need.
Hope this helped you.
On the Amana comfort zone air conditioner, there is a switch that says exhaust closed. Do I want the exhaust open or closed when i have the cool on the air conditioner
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Run fan continuous
Turn "off" the "energy saver" feature....
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
I want to program the fan to run continously
I don't see this as a 'programable' feature.
The unit is designed for the fan to run anytime the compressor runs and if you just want the fan to run all the time (without the compressor) just switch it to the 'fan/fan only' position.
18helpful
DOES ANY ONE REMEMBER HOW TO PROGRAM A AMANA PTH 093 B35 WINDOW UNIT TO MAKE THE FAN RUN CONTINUOUSLY? I AM IN HOTEL ROOM AND WOULD LIKE TO DROWN OUT THE CARS OUTSIDE ON THE INTERSTATE. THANKS
Press and hold up and down arrow at same time -press off twice to get into program mode (should read C1) -press heat button to scroll to C2 the use up arrow to scroll through options. You want to set it to read-out "On" then press off to set. This should be the continuous fan mode.
1helpful
2answers
Blowing of cold air every 5 minutes, and it says FP on the screen
FP is the code for frost or freeze protection. The unit will automatically do this periodically to prevent any damage caused by low temperatures although it should not be running as frequently as every five minutes. If the outside temperature is not low then it could either be a problem with the exterior thermistor (not the one you see from inside your room) or the control board could be on its way out.
1helpful
I have an amana air conditioner (ace245e). It
seems like the control board is bad,
if you have experience with electricity you can test the fan & compressor bi-pass the power from the board to the compressor terminal, if the compressor run you know for sure the board is bad
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
