Disable Itunes auto start when plug-in Iphone device. How To Disable AutoPlay For The Iphone On Your PC. disable itunes autostart iphone windows iTunes Autorun Disable How to disable iTunes auto-start on iPod docking
Click on the Start button in Windows 7 , type autoplay in the search box. Click on the AutoStart icon on the top. When the window opens, scroll all the way down and on the very bottom there will be two options under Device: Apple iPhone (set to "Take no Action) and Owner's iPhone (set to "take no Action).
Hope this helps.
Here is the easiest way for you to do that.
Hope this helps.
You can't post conmments that contain an email address.
You will experience your iPhone is disabled if you have entered the Face ID or Touch ID incorrectly multiple times. If you want to know how to deal with this issue and recover your iPhone, continue with this; To Fix A Disabled iPhone With iTunes or iCloud
Apple Inc.Nov 2, 2015 - ... forgotten your passcode, or if a message says that your device isdisabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't sync or connect with iTunes, use ...
How to Transfer Photos: Windows Vista/7 Users
If you have Windows 7 or Vista, there are two easy ways to transfer your photos directly to your desired folder or directory.
AutoPlay Method
When your iPhone device is connected, click on the Start Menu, and then Control Panel. Click Hardware and Sound. Select AutoPlay, scroll down to find where your iPhone device is listed, open the drop-down menu, and select "Ask me every time."
Step 1 - Connect your iPhone device
If you enabled the AutoPlay behavior using the method described above, you can skip this step, because your iPhone is already plugged in. If not, connect your device using the appropriate USB cable that your phone came with.
Step 2 - Import Pictures and Video
The AutoPlay prompt should appear with your device type listed at the top. Click the first link that says "Import Pictures and Video."
If for some reason the AutoPlay prompt did not appear, go to Start, then Computer, then right click on the icon for your iPhone device and select "Import pictures and video" from the context menu that appears.
Step 3 - Choose a directory, and import
Before you click Import, go to Import Settings, and select the "Import to" field to select the destination you want your photos to transfer to. By default, they will transfer to your My Pictures folder. You can also select the "Always erase from device after copying" option, though this is, as always, optional.
Click OK, then click Import, and your photos will be transferred to their designated directory.
Windows Explorer
If you don't want to mess with AutoPlay, you can find and transfer your photos manually using Windows Explorer.
Step 1 - Connect your iPhone device Step 2 - Click Start, then Computer
This should take you to a Windows Explorer page that lists your hard disk drive(s), and devices with removable storage. If connected properly, your iPhone device will register as a device with removable storage, and you will see the icon for it listed below this header.
Step 3 - Double-click your device's logo in Windows Explorer
Double-clicking your device will open it up as a directory, full of folders and sub-folders that store all of your phone's content.
Step 4 - Open your camera folder
Your camera folder should be located in [Your iPhone Device]\Internal Storage\DCIM\100APPLE. This means once you're in your iPhone's directory, click on the Internal Storage folder, then the DCIM folder, then the 100APPLE folder.
Step 5 - Transfer your photos
You can import your device's photos by selecting the ones you want, or pressing Ctrl+A to select them all, and dragging them onto your desktop. Or, you can hit Ctrl+C to copy the photos, and then hit Ctrl+V in the folder you want to copy them into.
iOS: Forgot passcode or device disabled
If you set up a passcode on your iPhone, iPad, or iPod touch, and you or someone else then enters the wrong passcode too many times, your device will disable itself temporarily. Learn what to do if you have forgotten your passcode, or if your device displays a message saying it's disabled.If you enter the wrong passcode six times in a row, you'll be locked out and you'll see this message:
iPhone is disabled
iPad is disabled
iPod touch is disabled
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. Here's how.
Use iTunes
If you have synced your device with iTunes, you can restore your device.
Connect the device to the computer you normally sync with.
Open iTunes. If iTunes asks you to enter the passcode, try another computer that you've synced with. Or try the steps below to use recovery mode.
iTunes will automatically sync your device and create a backup. If it doesn't, sync the device with iTunes.
After the sync is complete, restore your device.
When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup."
Select your device in iTunes and choose the most recent backup.
Use Find My iPhone
If you enabled Find My iPhone, you can use it to erase your device.
Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
Continue holding the Home button until you see the Connect to iTunes screen.
iTunes will alert you that it has detected a device in recovery mode.
First of all make sure your system and your iPhone connected to same wifi network. Try to disable and enable network adaptor of your PC using Device Manager, also disable and enable wi-fi connection after doing that Make sure you have enabled Wireless sync in your iPhone then restart the itunes.. Wait few seconds it will surely find out your iPhone.
First you need to download iTunes for your PC, download it here, once you download and install it, just plug your iPhone into your computer, and iTunes will automatically start up.
Hope this helps!
Hope this helps.
