Canon PIXMA MP830 All-In-One InkJet Printer Logo
Posted on Aug 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix error code 5C10, Alarm light blinks for Canon MP830 All in One InkJet Printer?
Joaquim Martins
Level 3:
Genius:
  • Master 1,128 Answers
  • Posted on Aug 07, 2010
Joaquim Martins
Master
Level 3:
Genius:
Answers
1128
Questions
0
Helped
298209
Points
3333
Try these step
First, make sure there is
no paper jam anywhere in the machine.. look inside, rear, where the
paper tray (output) is, etc to see if you find any shreds or torn paper
that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
Also, be sure that your scanner is UNLOCKED...
With the machine turned OFF:
Open
the document cover, look on the tray where the glass is -- and then
look to the LEFT side of the glass and you will see pictures of an
opened lock and a closed lock and a little switch...
Make sure the switch is next to the UNLOCKED position.
WAIT 5 seconds or so and then turn the unit back on.
If you STILL have the error code, try these two types of resets:
To clear the memory:
On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Wait approximately ten seconds and then press the <ON/OFF> button again.
Wait until the device has completed its cycling process before submitting another job request.To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is
not functioning as expected, it may be necessary to simultaneously
press Stop/Reset and ON/OFF buttons.
With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
I am trying to print on my Canon MP830 and I have had two error messages. 5C10 and 5100. I don't know what these errors are can you please help?
There seem to be a number of involved suggested fixes for the 5C10 error code.
Please go to this web page, and click the "Service and Support" link.
This will display a "Please enter your question" field. Type "5C10" into the field and click the Search button.
The first entry displayed will be a link to "ERROR LCD: Error Code 5C10" -- click the link
Three new links will eventually display:
  • Press ON/OFF switch to reset the multifunction device
  • Removing paper jams MP800R / MP830 / MP530
  • The MP830 may require repair
Click each link to see if the solution provided is appropriate to your situation.
Started up printer and received a 6A00 error code. Alarm light blinking. Printer a Canon MP830 printer.
Hi, the chat session got disconnected. Pleas start chat session again. you will not be charged again. I am online.
Received a service error 5C10, what do I need to do?
No 5C10 code to refer. I assume your error is 5010. If yes, that's mean your scanner unit is not functioning well. Need to replace it.
Warning light ON. Error messages:6A00, 5100,
regarding cannon printer mp830: how do I get to the printer carraige?
What is code 510c
Error Code 5C10 may indicate a problem with a paper jam, or your MP830 may need to be reset.
You may view the entire Canon support document on this subject for your model. You must be willing to use the "Search" feature. Type the question "Error Code 5C10" and click the <Search> button. Review the solutions.
Canon MP830 Error 5C10
2answers
Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
It is one of two things.
a bad ink cartridge (the chip located on the gold part of it)
or
bad USB cable.
IF you have a spare cable simply change them out.
If you are refilling your cartridges, it is time to replace them.
1helpful
Error code 5C10
Have you tested all your cartridges to ensure that they are seated properly?
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : [email protected]
old marine
old marine
ZJ Limited
ZJ Limited
