SOURCE: I have a HTC touch pro 1 and I am having problems
Ok,
for images : check your MMS settings if there's any restriction sizewise.
for music : insert desired music file to phone or memocard root menu. Your phone support .mp3, .wav files. Use built in Music trimmer to make ringtone(should be up to 30 sec.)
for weather: not all town are in database,some countries have only capitals displayed.
Get app called Advanced Config Tool and you'll be abble to do a lot of tweaks in your device.
SOURCE: I am having htc wildfire.
U CAN DOWNLOAD THE SOFTWARE FROM THE BELOW HTC SITE
http://www.htc.com/www/SupportDownload.aspx?p_id=316&cat=3&dl_id=1058
SOURCE: I am having htc wildfire. so i need pc suite for
hi,
Visit to the given link and download and install the "HTC Sync 3.0"...
http://www.htc.com/www/supportdownloadlist.aspx?p_id=316&act=sd&cat=all ...
hope this has helped you..
Please rate the answer.
Thanks...
SOURCE: I accidentally removed the clock/weather
It's actually a pretty simple way to add widgets back to your home screen.
Long press a blank area of your home screen. A dialog box to Add to Home will appear. Select Widget, and then select Clock [HTC]. You will be able to select from 12 different HTC Clock widgets. Select the one you like, and then press the Select button. It will appear on your home screen as long as there is enough room for it. You can move the widget around by long pressing on the widget and sliding your finger to the desired location on the screen.
Good luck.
