what e15 indicate means an error code that there have been an over flow of water from the drum over to the panel or the wire that suppl power to the screen .
what
you will have to do to fix up this problem from the screen is to
unscrew the screws with screw driver care then trace the wire ,that is
the power supply down to the panel and also to the screen clean up all
forms of liquid around the wires and also the panel carefully . then
couple it back with care to is position with this the problem is solve.
thank you.
