After turning on the large burner (bottom left), all igniters continue to spark. All other burners function correctly. This condition happens when other burners are on or off. I have removed the burner and cleaned it along with the igniter. Is this just a bad igniter or a sign of something else? Thanks
SOURCE: Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
I have the same cooktop. The igniter on the top right burner will not shut off when I use the simmer burner on the lower left hand side.
The large front burner won't light using the igniter but will when I use
a match. Regardless they all continue to spark even after it's lit.
All other burner function normally.
Igniter continues to spark after the burner ignites
