GE 29878GE1 Digital Answering Machine Logo
Posted on Aug 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i check messages on my answering machine away from home?
Anonymous
Level 3:
President:
  • Master 1,285 Answers
  • Posted on Aug 07, 2010
Anonymous
Master
Level 3:
President:
Answers
1285
Questions
Helped
297017
Points
3126
Dial the phone (use a cell for test run/practice) ...once you hear the message press "*" (the asterisk key) and enter your 4 digit code (the default code is 1234 or sometimes 0000) you really should change this, this might have been done in the initial setup... read your manual for the exact commands (to save, delete, skip or repeat) to be use after/during retrieving msg....
Motorola SD451 won't let me check messages when away
Looked at a Motorola Manual and it states:
1) Dial your home number
2) When your Answer Machine
3) Enter Security code 50*
4) If you have not setup the mailboxes enter 1
2helpful
How do I retrieve my voice mail when I'm away from home?
Go to the base unit.
scroll to the answering machine option.
Under there is a setting for your security key.
you can read what's there, or change it to your own two digit code.
when you call in, during the message, enter that two digit code and it'll go into messages. There's a "toll saver" mode so that the machine answers after two rings instead of 4, so that if you call and it rings 3 times, you know there's no new messages.
Manual:
http://www.uniden.com/pdf/DCT648-2om.pdf
2helpful
How do your retrieve messages from home while away from home
Here's the manual:
29869GE2 Digital Answering Machine
You will need to set a security code. When you're away you can call your home phone and enter the code to retrieve your messages. Hope this helps.
I have a Power Max phone with two extensions.  I'm having trouble retrieving messages when I'm away from home. I can't find my instruction manual. I think this is operator error.  How do I collect...
I found the answer to my question on line. I dislike paying for information that should be available to me at no cost. I will instruct my tech person not to purchase your equipment any longer.
  Dr. Morris Schajer
Tam 100
Call your number and as soon as your answering machine is about to come on do what you would normally do from home...ie: if you are with bell then it would be *98 then it will ask for you password ...
i hope it works for you
New Uniden DECT2080 answering system not holding messages
How can I check the answering machine when I am away from home.
At&t 1717 answering machine
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Deleting Messages
Delete All Messages
After you have listened to all messages and
heard the two beeps, press 3 ,3.
Delete Selected Messages
Press and release 3 while the message you
want to delete is playing.
CHECKING MESSAGES
First call your home number, when the answering machine picks up, dial 0 then the two digit security code. (You have to check the security code on the handset.) It will then give you voice prompts how to listen, skip and delete messages.
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
