Question about HP Creative Sound Blaster Audigy 5.1
Sound problem sir ive properly attached my speaker in the sound ports and ive all my motherboard and sound card driver but ive a problem " my sound is less even i kept full vol"
купил карту поставил не пашит ищю дрова помогите (звуковая карта верся 5.1 Genius)
Posted on Sep 14, 2008
I CAN NOT HEAR NOTTHING FROM MY COMPUTER
Posted on Sep 11, 2008
    President:
  • 2,712 Answers
Open the Volume icon at the bottom right of the screen and choose 'properties'
This will open a small box. Make sure all the level indicators are at maximum and nothing is muted. Also check in the soundcard software if you have selected any "effects". If you have, try playing around with the different options and see if that helps.
If this does not help, try the speakers on a different PC. Should you encounter the same problem there as well, it could be that the speakers are defective.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If, however it has not, then please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best as I can.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 28, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    etc, and I will try to assist you further as best I can.
    IrishDruid
6ya staff
SOURCE:
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
I have a philips ls1400.the bit the speakers plugs into is attached to the motherboard but the pc keeps saying that no sound card is installed
install your sound card driver.. download the driver here http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/
Apr 18, 2011 | Computers & Internet
Good morning sir my computer configration is
Have you installed proper driver related to proper Operating System, if not download it from here
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
search for the motherboard and then download it. Otherwise it might be a problem of sound card or speakers. Also check that the volume controller from the OS if it is in mute state or not.
If this doesnot solve your issue, give me a feedback with more details of the problem it will help to solve your issue.
Jul 01, 2010 | Intel Motherboard
Ive been reformated my computer,thees no sounds from my speakers
Make sure you plug your speakers into the green port of the audio card. One port is aplified and one is non aplified. On some cards they have 5.1 output and usually the green is the front.
Dec 03, 2009 | EliteGroup K7SOM Motherboard
I can't have a sound and audion output.What i need
Good day sir/ma'am, hi, If your motherboard does not produce sound, it could be any of the following:
  1. Your device driver for the sound is not yet installed. locate the CD that come with your motherboard. your sound card model is realtek alc 655 as shown in this website : http://www.biostar-usa.com/app/en-us/mb/content.php?S_ID=209 if you cannot find the driver download it from this site: http://www.biostar-usa.com/app/en-us/mb/driver.php?S_ID=209
  2. Your volume is either in mute or i a low volume setting. Check the taskbar at the lower right side of the desktop if you see a speaker icon, right click it and set the volume level to high.
  3. Your speakers is not connected to the audio port. Check the baby plug stereo speaker connector to the green audio port at the back panel of the PC, (usually pink, blue and green are side by side)
  4. Your speakers are not working properly. If you have portable mp3 players, plug in your speakers to it for testing.
  5. Worst come to worst if your green audio port is the defective one. you can use the blue one provided you enable 4 channel, so sound is sent to the blue port.
  6. your built in sound card is bad, you can get a replacement soundcard of any brand, provided its PCI slot. or get those small USB type sound card.
If I miss anything feel free to ask, hope these will solve your sound problems.
Nov 13, 2009 | Biostar K8M800-M7A Motherboard
No audio to speakers on hp 552w com
Good day sir/ma'am, hi, If your PC does not produce sound, it could be any of the following so check the list one by one:
  1. Your device driver for the sound is not yet installed. locate the CD that comes with your PC. I could help you find the driver if you add any information about your PC model or motherboard maker, you can download the driver at driverguide.com, just note the maker and model.
  2. Your volume is either in mute or in a low volume setting. Check the taskbar at the lower right side of the desktop, if you see a speaker icon, right click it and set the volume level to high.
  3. Your speakers is not connected to the audio port. Check the baby plug stereo speaker connector for open wires, if the wires are good connect it to the green audio port at the back panel of the PC, (usually pink, blue and green are side by side)
  4. Your speakers are not working properly. If you have portable mp3 players, plug in your speakers to test the speaker unit itself.
  5. Worst come to worst if your green audio port is the defective one. you can use the blue one provided you enable 4 channel, so sound is also sent to the blue port.
  7. Check also the BIOS setup, see if the built in sound card is enabled.
Nov 09, 2009 | Computers & Internet
Sounds not work
  1. Your device driver for the sound is not yet installed. locate the CD that come with your motherboard. your sound card model is realtek alc 650 as shown in this website: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00006230 if you cannot find the driver download it from this site: http://driverscollection.com/?file_cid=4053691085452095b98d66543d7.
Nov 08, 2009 | MSI MS-6390 (-6390-010) Motherboard
No sound from X-540 speakers
are you getting power out of the speakers? tried them elsewhere? maybe the port burned out on the board and an audio card maybe needed. try an audio card and see if that works and return to best buy (if you have one near you) if thats not the problem. you can try to reset your motherboard to default values? if the computer shows your drivers working properly then maybe its the speakers. ive seen tht happen to good speakers. its a bummer deal!
Jun 06, 2009 | Logitech X-540 Computer Speakers
Sound drives are not accepting
Please Install the the proper drivers for your sound card. Make sure the speaker jack is connected to the speaker port of the cpu. Thank you....
Sep 10, 2008 | Intel Motherboard
HP Creative Sound Blaster Audigy 5.1 Logo
65 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
