SOURCE: I have an american standard
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
SOURCE: We have purchased a whirlpool tub model #
Some jets you can stick your finger into the jet its self and move it in 360 degrees. Others have a notched round trim piece that when turned counter clockwise, will loosen the jet where you can manipulate it as described above. You will need to retighten it after your done so it doesn't end up the same way. If you have trouble, you may want to use a little spray lubricant on it so it will loosen.
SOURCE: My american standard jacuzzi tub is pluged in but
check for power at plug in if power your vacume switch is probably out replace switch.
SOURCE: how to remove jets from american standard jetted
Jet trim usually unthread counter clockwise out of the wall fitting
SOURCE: American Standard whirlpool model 2425 how much stuctolite 50 lb?
some people use spray foam which you can add later
