Question about Gb Electrical 100 Amp GE Load Center
I need a wire diagram for a high voltage Baldor motor CAT # 054180 79151 connect to 440VAC it's a 40HP, RPM 3525 , 3PH and it's SPEC# 40F97Z22 please help
  • 20 Answers
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7 Connect #5 to #8 Connect #6 to #9
Connect supply phase A to #1 Connect supply phase B to #2 Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
Posted on Aug 05, 2010
6ya staff
SOURCE:
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
Baldor motor wiring diagrams
The diagram is almost always either on a label on the side of the motor or on a label inside the little connection hatch.
Jul 26, 2014 | Baldor 7.5hp 3450RPM 213T Frame ODP...
Need wiring diagram for 230 v for delta table saw cat. #36-451
Is the motor designed for dual voltages? The manual does not have a wiring diagram. I assume the motor lable diagram is faded or missing.
Dual voltage motors contain two sets of winding. Each set is rated for the lower voltage. To operate the motor on the higher voltage the windings must be connected in series. AND, they must be connected in the same direction. I use a variac to apply 30-40 VAC to the coils in various combinations, then measure the open lead voltage to determine the proper connections. This test should be performed by a licensed electrician.
Dec 05, 2013 | Delta Saws
I need to wire up a baldor 3 phase motor 208-230/480 15hp and dont have the wiring diagram to know what wire is what or where to hook it to?
Hi Casey, I'm an electrician and can help you with this problem.
First, a disclaimer. Without the catalog number of the motor you have, or a wiring diagram for it, no one can tell you how to wire this motor with any certainty. With that said...
Nearly all single speed 3 phase motors have 9 leads (numbered 1 thru 9) and can be wired for either "high" or "low" voltage. Most of the time, high is 480 volts and low is 208/240 volts. Given that you posted the amperage as "41-38 / 19", I am 99% confident that 41 amps is at 208 volts, 38 amps is at 240 volts and 19 amps is 480 volts. Further below is the way to wire unless the motor manufacturer or name plate indicates differently. You will need to determine the voltage of the appliance this is going to be installed into. You should be able to find this on a name plate of the appliance - but it may provide a dual voltage spec here, too. If this is the case, you will need to *carefully* measure the voltage with a meter, or find out the voltage of the electric panel that feeds the appliance.
Once you have learned the incoming voltage, you will connect the motor as such when L1, L2 and L3 are the line voltage supply wires and wires 1 thru 9 match the numbers on the nine wires from the motor.
208/240 or "Low" volts:
Motor leads 4, 5 & 6 connected together and wirenut.
Motor leads 1 & 7 to L1 and wirenut.;
Motor leads 2 & 8 to L2 and and wirenut and lastly,
Motor leads 3 & 9 to L3 and wirenut.
480 or "High" volts:
Motor lead 1 to L1 and wirenut,
Motor lead 2 to L2 and wirenut,
Motor lead 3 to L3 and wirenut,
Motor leads 4 to 7 and wirenut,
Motor leads 5 to 8 and wirenut and lastly,
Motor leads 6 to 9 and wirenut.
The motor should be operated briefly or "jogged" to determine the direction the motor turns. If the motor rotation needs to be changed, simply swap any two "L" wires (swap L1 and L2, or L1 and L3, or L2 and L3). Test once more to verify rotation and when correct close the wiring compartment and complete the installation. Swapping the L wires will likely be much quicker and easier to do at the magnetic contactor instead of the the motor's wiring compartment. Either location is acceptable.
You should try to obtain the name plate data for this motor - if at all possible to to make sure of the voltage and wiring method. I hope this helps & good luck!
May 13, 2012 | Gb Electrical 100 Amp GE Load Center
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone...
OC3012F12SPCYL OIL CAP 12MFD/370V
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
http://www.baldor.com/brands/baldor-dodge/contact-us/contact
https://www.baldorvip.com/servlet/productInfoPacket/1022W.pdf
Jun 15, 2017 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I need a multi 110/230 volt wiring diagram for a baldor non reversible motor
http://www.baldor.com/support/literature_load.asp?ManNumber=MN1240
You didn't give a model,here's a manual on their motors and the wiring diagrams,they start on page 2-9.It should get you there,or you can check out their other manuals on the same page .Take care!
Jan 13, 2010 | Target Portable Masonry Saw PS1411S...
Need a wiring schematic for a dual voltage masonry saw motor. it s a baldor motor on a target saw
http://us.husqvarnacp.com/
drop down menu "service"
click "service literature"
click "old target, dimas, partner literature"
enter model number
pdf has basic wiring diagram page 4 or so
Dec 12, 2009 | Target Portable Masonry Saw PS1411S...
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
Gb Electrical 100 Amp GE Load Center Logo
424 people viewed this question
Top Gb Electrical Electrical Supplies Experts
Fahr Quad
Marvin
Marvin
rd2xpld
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
