Question about Sew D'Lite Lightweight Portable Mechanical Sewing Machine
I'm trying to thread the machine to sew a pillow and the thread comes completely out of the needle when i begin to sew.
  • 255 Answers
Hi. Make sure you have at least 3 inches of thread pulled through the needle when you begin to stitch.
Robbie
Posted on Aug 06, 2010
Anonymous
SOURCE:
My singer 8500q will sew about 8 inches then the top thread breaks
Try this: Remove the top thread completely from the machine. ALWAYS RAISE the presser foot and rethread from the beginning.
Jul 01, 2018 | Singer Sewing Machines
The thread in the needle in My Brother JX2517 keeps coming out from the eye every time I try to sew. It does not break bot comes out of the needle. What is the cause and how do I fix it?
Pull more thread tail through the needle eye and hold the thread tail in your left hand when you begin the first couple of stitches. It also helps to have the needle at its highest point when beginning the first stitch.
Jan 15, 2018 | Brother Sewing Machines
200 thread breaking
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3. Needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and bobbin thread are not set under the presser foot before sewing
6. The thread is either too heavy or too fine for the needle
7. The needle is not the correct one for the fabric being sewed
8. Check for burrs on the needle plate
Dec 23, 2015 | Sewing Machines
Keeping the thread in needle when you begin to sew
after threading the needle pull about 6" of thread out the back under the press foot
that way the thread is jammed under the foot and is held in place for the next thread
bobbin thread should also be out the back
when you have finished sewing then lift the foot and move the material sewed about 6"" away from the foot before cutting the threads
Nov 03, 2015 | Sewing Machines
The thread is coming out of the needle
too much tension then . or too big a needle.or the bobbin is not working at all
May 09, 2015 | Sewing Machines
Needle won't remain threaded
make sure the thread has long thread tails of 4 to 6 inches long
and have the thread tails pulled behind the needle before starting
to sew.
Jan 04, 2013 | Michley Lil Sew Mechanical Sewing Machine
My machine keeps clogging at the beginning of my sewing
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Janome Sew Precise Mechanical Sewing...
I was sewing on tshirt material (an actual tshirt) and the understitching was a mess of thread. I messed with tension and thread and bobbin and it finally started sewing correctly. Now I am trying to sew...
Go to www.singerco.com and download a manual for free, also they have a lot of good tips on their website. I know some basics, make sure that you are not using old thread, and the right size needle for the job.
Oct 23, 2010 | Singer Sewing Machines
My thread often becomes unthreaded from the part that raises and lowers the needle causing the thread and fabric to jam up
Your needle should not come unthreaded in the middle of sewing.. if it does, it is because the thread breaks. this can be a simple tension problem or brittle thread.
if you are talking about at the beginning of sewing that the needle comes unthreaded, then you should just pull out 6-8 inches of thread through the needle before putting your fabric under and begin sewing.
i hop that helps.
Apr 16, 2008 | Singer Featherweight 132Q Mechanical...
Sew D'Lite Lightweight Portable Mechanical Sewing Machine Logo
369 people viewed this question
Top Sew D'Lite Sewing Machines Experts
Renee Knafel-Bullock
Jimmie Sill
Are you a Sew D'Lite Sewing Machine Expert? Answer questions, earn points and help others
