Peugeot 307BR Wrist Watch Logo
Posted on Aug 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Got a high bite point does my clutch need replacing on my peogeut 307 02 plate
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Aug 05, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291866
Points
7081
If you have to lift your foot off the floor to let the clutch in, then the plates are worn out and may soon stop driving.
Replace them soon!
tip
To open watch case, hold back of watch up with arrow pointer on the back plate...
If you don't have the proper watchmaker's tools (and you'll need several!) I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you. Most Sears stores will do it while you shop.
on Jun 05, 2010 • Watches
tip
Clock Bushing Replacement
BUSHING TIPS
-One of the most common stoppage problem is caused by increased friction and mostly due to lack of incorrect amount of or lack of oil. If discovered in time, the movement can be cleaned and oiled with only high quality Clock oil, then it will be good for another 5 years or so. Insufficient lubricants eventually cause wear in the pivot holes and/or bushings.
-After a pivot is worn it will change the depth of the wheels and pinions to such an extent that the power train will stop due to improper gear meshing. Wear causes a pivot hole to become egg shaped.
HOW TO TEST
-One testis to completely let off the power from the power train and rock the main wheel back and forth. Then you will clearly see the pivots that have the problem jumping back and forth.
Sample one:
Sample two:
Examples of EGG Shaped pivots above.
WHEN DO YOU NEED BUSHING REPLACEMENT?
-One rule of thumb used by many repair persons, if a bushing is worn one third or more the diameter of the pivot it needs to be replaced.
-Above is Two example of a worn pivot's [note the black gum med up oil around the pivot in photo above]. This is a dead give away of a potential problem.
centerline PIVOT
-Before disassembly, mark all bushings that need replacement in the correct geometrical direction of centerline.
-Complete disassembly of movement is required.
-Then you will need to file out the exact opposite direction with a small file, this will ensure that when you start drilling out the hole it will be centerline.
-Set-up the drill press and lock the plate on to the drill press making sure you find the centerline of the original pivot hole. Use a steel short stock the same diameter of the old pivot and chuck it in the drill press after the plate is secure, select the proper bushing that you intend to press in.
PRESSING IN THE BUSHING
-With a small broach taper slightly the inter plate before the insertion of the bushing. Do this from the inside of the plate, this will ensure that the bushing will never fall out.
-Select a bushing that is a bit undersized after it is pressed into place, then open the hole up to the correct diameter.
-Use the drill press to push in the new bushing from the inside plate out.
-Be sure to broach out the pivot bushing in both directions, this will leave the hole in an hour glass shape ”===)I(===” and will reduce friction.
COUNTER SINKING.
- Counter Sinking is very important and not only needed to hold the oil in place but also to reduce the amount of actual friction on the pivot. [Note:] don't get carried away the first gears tend to have a lot of torque on them and a lot of bushing surface is needed; however, the final pivots do not and are very sensitive to friction.
-Barrel Bushings, these are often overlooked. This is an example of a bushing before and after replacement.
Hope this tip helps.
R/
David
http://antiqueclock.clockstop.com/bushing.htm
on Jan 22, 2010 • Watches
How do u change battery in yves camani watch please
For a quality watch like that I would recommend using a specialist watch repairer as they can reseal the watch to be water tight after the battery is replaced.
Could you possibly comment below with a photo of the back of the watch?
There are three main types of watch back plate. Push fit, screw down and screw on.
Push fit is usually a smooth back cover with No notches or grooves. These can be gently levered off to replace the battery then pushed down to 'click' back into place. Some have a slight notch on the body or back plate to make removal easier.
Screw down back plates have dimples or notches at regular places around the edge. This is to allow grip to unscrew the whole back plate. Some versions need a specialist tool to unscrew them.
Screw on plates use four tiny screws to hold the back plate down. These are more commonly used on 'Sports' or digital watches.
4helpful
We cannot remove the back plate and there are no screws. The person who sold us the battery was unable to remove the plate, also. HELP!
Thank you for contacting FixYa.
I am not 100% sure of the back of this watch, but since it has no screws I can assume it just has a snap-style back.
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • Pull out the stem, which releases the back on some watches.
  • Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • My only other suggestion would be to take to another jeweler who is more experienced then where you went before. This should be an easy battery for someone who is capable.
    Best regards.
    Jewel
    1helpful
    How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Can the bezel be repainted and the crystal replaced for a reasonable cost
    mcdevito75 Here, Your watches bezel can be re-plated and the crystal replaced, I have a repair person who does expert work, specially on high end watches, Tag Heur, Rolex, etc. contact me at [email protected] for details.
    1helpful
    I need help identifying waltham pocket watch
    Try going to "http://www.antique-pocket-watch.com/".
    This site seems to be a good point in the search for information on antique watches.
    It has a few links to other sites.
    6helpful
    How do I manually wind my Omega Seamaster Automtic Plz
    I'll make it easy and with a little fun for you!
    First -lets assume that the winding crown of your watch is the one of the weels fitted on the car.
    Imagine the car which is driving across your watch dial from point 6 (six o'clock) to point12 (twelve o'clock).
    Which way the weel of the car is turning?
    So, the winding of the watch is executed exactly in the same direction as the weel turn of that car when it goes from point 6 to point 12.
    When you wind the watch in that direction, the winding pinion and the clutch wheel (both are parts of setting gear) gets engaged and through the gears turns the barrel which is housing the mainspring.
    When you turn the winding crown in opposite direction, the winding pinion and the clutch weel gets disengaged due to the specially angled weel teeth and no action in the setting gear is taken. All you hear is just a rapid clicking sound when the wheel teeth are jumping over each other.
    I hope this is Fixya.
    Do not forget to rate, please.
    Top Peugeot Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Peugeot Watch Expert? Answer questions, earn points and help others
