I have a vertical black stripe about 3-4 inches wide right of center on screen that wont go away.
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
SOURCE: philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Just happened to me with a 42PF7320A/32, cust service told me to take in to a repair shop.
Same stripe but it progressed from being narrower to the current width.
