My water supply threads coming out of my wall are larger than the threads on the back of my refrigerator for the ice maker. How can I fix this without a big hassle? I have already looked for a reducer fitting of some kind, but I have not been able to find one. Is there a special kit that I need?My water supply threads coming out of my wall are larger than the threads on the back of my refrigerator for the ice maker. How can I fix this without a big hassle? I have already looked for a reducer fitting of some kind, but I have not been able to find one. Is there a special kit that I need?
You can't post conmments that contain an email address.
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Same issue with water leaking. Fan slowed and allowed ice to block drain..., defrost caused ice dam under heat shield. (behind freezer fan shroud at bottom, below condenser) Ice dam lifted heat shield until it dislodged the condenser, which slid down and melted the plastic liner when the defrost came on. QC! Fixable..., but could have been avoided by mounting the condenser so it couldn't shift or drop in transit. New fan and heat shield needed now..., and more groceries! Any good leads on reasonable parts in Belleville Ontario area?
i have the same fridge there are 2 screws down the bottom one is behind a round plastik cap you have to pop out the the top has 3 screws that is it not that hard then it pops off unplug power cable plug and clean to your hearts content. mine wasnt pumping water out the inside hose popped off easy fix it took me 3 years to get around to fixing it today
