Dell Trinitron monitor/ Frozen in power save mode...won't activate from keyboard or mouse. Of course can't access Control Panel as has been suggested. Please help.
-Turn off both computer and monitor -unplug monitor from computer(still plugged into power supply) -turn on computer and monitor(monitor is still unplugged) -After computer is on for about 30 sec. plug monitor into computer -turn off both monitor and computer(now connected together) -turn on monitor then computer and should be good to go!!!Here's redlegs1 solution:
AnonymousJul 07, 2008
In my pc im getting a problem of power on safe mode
I have an LG flat-panel monitor connected to an HP Pailion Desktop. Both are fairly new, only about 3 years old. Last night, while I was checking my email, the screen just froze and would NOT respond to the mouse nor keyboard. Even when I tried "CTRL + ALT + DELETE," nothing happened, so I was forced to improperly shut down my computer. When I pushed the power button to turn my pc back on, a "Power Saving Mode" window appeared on my screen, and I've been stuck on that all day.
I tried the suggested solution 3 times, but to no avail. Could it possiby be my keyboard? After I attempted to reboot, I noticed that there were NO lights on my keyboard. I checked that all cables were properly connected, and I even turned off my power strip altogether at one point, just to give everything a fresh start. Nothing seems to work. Please help! Thanks!I have an LG flat-panel monitor connected to an HP Pailion Desktop. Both are fairly new, only about 3 years old. Last night, while I was checking my email, the screen just froze and would NOT respond to the mouse nor keyboard. Even when I tried "CTRL + ALT + DELETE," nothing happened, so I was forced to improperly shut down my computer. When I pushed the power button to turn my pc back on, a "Power Saving Mode" window appeared on my screen, and I've been stuck on that all day.
You can't post conmments that contain an email address.
Followed the directions of redlegs1, posted 12/26/2007. It didn't work the first time, but sure did on the second attempt. Thanks redlegs1, you're no apprentice my friend!
A solid amber light indicates a pre-POST failure has occurred. The system has received a Power Good signal from the power supply so it's not a power supply issue. HERE is the documentation that tells what the lights mean and possible solutions.
Dell monitors automatically go into power-save mode after a preset
amount of time when the computer is inactive. The Dell monitor will go
completely black, instead of showing a screensaver. This doesn't mean
that your Dell computer
has shut down. Instead, this allows your monitor to essentially turn
off until it's needed again. You can change how long it is before the
Dell monitor goes into power-save mode by changing your display
settings.
Step 1
Press
any key on your keyboard or move your mouse. Either will turn off
power-save mode. Alternately, you can press the power button on your
Dell computer tower or laptop.
Step 2
Press
any key a second time if the monitor goes from power-save to stand-by
mode. Stand-by mode allows the screensaver to appear.
Step 3
Enter
your user name and password into the login prompt if your computer
requires a login. Press "Enter" to begin using your Dell computer.
Step 4
Change
the display settings on your Dell monitor to prevent your monitor from
going into power-save mode prematurely. Right-click anywhere on your
desktop and choose "Properties." Click the "Screensaver" tab and press
"Power." Beside "Turn off Monitor," choose a time amount from the
drop-down list and press "Apply."
Usually hitting a button on the keyboard or moving the mouse works.
If it is really a problem go into your display settings through the control panel, access the power options and stop your monitor from going into powersave mode.
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
Hold down the function key on your keyboard (lower left hand side of your keyboard between the control key and the windows key) and the F8 key simultaneously. This cycles through all monitor set up modes.
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
