Mcdevito75 here, Sounds like you have the time set, but the date is a fifferent matter, Here"s what to do, the stem (winder) of your watch has 2 positions, slip a fingernail just under the stem, and gently lift the stem to it;'s first position, this position allows you to change the date without so many cycles of the entire watch, it"s a little tricky but you"ll get used to it. Once you get this first position set the date to 1 day before the date you want, now pull the stem out to set the time of day, go thru 1, 24 hour cycle to set the date you want and time of day. The date is now set and will change on time, approx. Mid nite. Hope this helps.
