Hello, we are living problem with our printer B-SX4 with error code SG-1511-15 what is your comment about our problem ? Thanks alot for your kind attention.
Re: Hello, we are living problem with our printer B-SX4...
Either you driver is not correctly interpreting the image data or you have a problem with you connections. This is syntax error detected due to missing or unorrect datas.
28113 - Ink supply timeout error (Tank 3 error)
• ink supply pump error
• air sensor error
• The tank feeler is malfunctioning.
• ink level senor error
• The ink supply pump is faulty.
• The carriage is faulty.
• The ink level sensor is faulty.
• The CTL board is faulty.
• Turn the main power switch off and then back on.
• Replace the ink supply unit.
• Replace the carriage unit.
• Replace the air purge detection switch.
• Replace the CTL board.
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Well at my old company we use to get our's fixed and replaced from toshiba TEC in London. Campus 300, Spring Way, Maylands Ave Ind Est Hemel Hempstead, Herts, HP2 7GG United Kingdom
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
