Hello & Welcome to FixYa F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions. Kevin
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Hello there: Here is the code for these 2 codes hope they are very helpful for you
F3
Open
or shorted
oven temperature sensor
Replace
oven
temperature sensor
F5
Hardware
and watchdog circuits disagree
Replace
clock
assembly (also called the ERC)
Hi. This code is the result of a shorted, or open(circuit) oven temperaturesensor device. You will need to Check the sensor harness and harness connection between the oven sensor and oven control.
Replace the oven temperature sensor (RTD) if wiring is ok.
