I just got a new number on my sch u340, but because I had to reset the phone the lock was reset and I can't unlock it. Is there any code to bypass this?
Hello The master reset code is: #*7728# This will not delete anything from your mobile phone, but set each and eveything to its default/standard setting as it was on the time of purchase.
To unlock your phone put a sim from another company, now type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested) Hope this helps
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up
You can reset the phone with the following code, but you will loose all of your data. Type in the following: *2767*3855#. This will reset the phone to the factory condition like the day you got it
Do you have the codes already or are you looking for the codes ?
If your looking for the codes come visist us.
If you have the codes already the company you got the codes from should have support.
