To reset your laptop to its factory state you need to restart or turn it on, then just tap F10, It will ask you on how would you loke to restore then select Restore system to factory settings. Usually it would ask you for a password just etern six zeros "000000" it should work. Please wait until the restore process is completed.
Note: All data will be deleted so make sure you back up them first before you do a Restore to Factory Settings
Thanks for using Fixya
Unlike
other laptops, Acer laptops integrate a computer management utility
called 'Acer eRecovery Management' to create backup of hard drive data,
create restore point, reinstall applications & drivers, and reset
Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to
reset your Acer laptop. This process will erase all data from your hard
disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop, feel free to get expert technical assistance at http://www.vtechsquad.com/acer-support/
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
