How do i take it back to factory settings
Remember to back-up all off your important documents, files, photos etc to a backup external hard drive, USB stick etc.
you
can use the restore function of Acer Recovery management
by following the procedure below-
Step 1:
Click “Start” menu.
Step 2:
Click “Programs.”
Step 3:
Click “Acer Recovery Management.”
Step 4:
Click the “Restore” button on the bottom of the dialog box that opens.
Step 5:
Click “Restore System to Factory Default.”
Step 6:
Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click “Start” to restore the computer to the default factory settings.
//javaftper
Try clearing privacy data in browser to get a bit of ram back. If no good , do hard reset, you'll need to re-set up phone so back up first. Then type *#7370# and use passkey 12345 and phone will re-start and be like'out of the box' your memory card will not be affected.
If the problem continue, you should remove the memory card.
If the problem persist after this, try uninstalling those apps that you just added after you purchased your phone, restart, and then try to use it again as usual. It must be a program glitch or a software conflict.
If the problem persists, then you might got to go to the service center of nokia for reformatting or upgrade of firmware.
Good Luck
