Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
Posted on Aug 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Anonymous
Level 2:
Scholar:
  • Expert 104 Answers
  • Posted on Aug 01, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
17960
Points
328
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
I cannot get a dial tone. I press the talk button to dial out. After 3 quick short beats a message appears in the display window " can't connect ". The phone rings when in coming calls come, but...
Which make and model of phone is it?
Are you pressing the green call button beforew you try to enter the number you are calling?
You should enter the number first, then press 'green'
You wont hear a dial-tone like a landline phone
Feb 23, 2011 • Cell Phones
2helpful
How do i program pohone numbers
This just worked for me:
Press the Speaker button at the bottom right of the unit - you'll hear a dial tone.
Press Program.
Dial the number you want to put in memory.
Press the one-touch button where you want to store the number - press it long enough to hear 2 quick beeps.
Press Program again.
Press Program AGAIN, holding long enough to hear 3 or 4 quick beeps.
I hope this works, because I'll come looking for my own solution next time I need to program one of these!
9helpful
2answers
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
7helpful
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
1helpful
2answers
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
20helpful
2answers
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
1helpful
Uniden 900MHz phone model EX17960A
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
3answers
Programming a number for memory
Memory
Speed dial instructions
make sure phone is off not in talk mode- then press the memory buton-press desired number 1-9-press memory button again,the display shows enter name -press memory button to save the name.then the display shows enter number-enter the number then press memory again and you will hear a tone that confirms
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
