Hi
I have a digital camera Kodak Easy share C310. Can I use a 1 Gb SD memory card in it? Do I have to format that card if I can use it? Can I use a 2 Gb card in it?
Thank you
Ross
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
Hi, This is from the Kodak website, bad news: Question
Can I use a 2 GB Secure Digital (SD) memory card in my
KODAK EASYSHARE C-Series Digital Camera?
Answer
No, your digital cameras is not compatible with 2 GB
SD memory cards; your camera accepts a maximum 1 GB SD card. Hope this helps.
agreeing with fixer1950. This model is in fact just designed for up to 2GB SD or MMC card.
When Easyshare one was released, 4gb SDHC was not yet created. You will always get the "memory card requires formatting" (looping until you get a file sys error msg) if you will keep on trying to use the 4gb.
Which size has the memory card? More than 1GB?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards. Why download firmware version 1.07? This firmware version improves memory card compatibility and provides general performance updates. KODAK EASYSHARE C330 Zoom Digital Camera Firmware
try doing a format with the camera. check your manual to see how to do this with your camera. Beware, formatting will erase anything on the card. i actually had the same problem with my camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
