I have a panasonic 50 inch tc-50px24 plasma tv. i am trying to connect wireless speakers to it and cannot get them to work. they are connected into the audio port but the signal is not there.
Did you try holding the power button down for about 30 seconds and release it? There are a lot of videos on plasma sets like yours that have this issue. I would wager the power supply before the main board.
Check the speakers first. If found OK, check and replace damaged component/s at it audio output circuit board, or replace the audio output circuit board as card basis.
a suggestion, take it back and tell them when you opened the box it was this way--a whole pc board is likely to have to be replaced that has the connection on it.
"Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases."
You'll probably need to call a repair man to fix your TV.
Panasonic Plasma 50 inch will not power up
