Mitsubishi WD-65731 65" HDTV Logo
Posted on Jul 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi tv I buy mitsubishi 65731 65 in tv and i having problems with it. I was watching tv and the tv shout off and 2 light on the tv and the lights flash off and on.
Chi Chu
Level 3:
  • Mitsubishi Master 8,457 Answers
  • Posted on Jul 31, 2010
Chi Chu
Mitsubishi Master
Level 3:
Answers
8457
Questions
0
Helped
2821067
Points
26282
How long was the lamp last change?It was more 1 1/2 or 2 years must change the lamp.Life of the lamp it over.
Mitsubishi "wd73642 I'm watching tv and then it shuts off and the status green light blinks green fast and the light goes off do i need a new dlp lamb
I have a Mitsubishi WD73642 model which I'm having a problem with it turning off. When power is turned on the status light flashes green and appears to be powering up. Then u hear sound. Picture comes on light turns sold green then within a minute the El TV will just turn off no other dianososis lights. TV is not located too close to the Wall. Any ideas why?
1helpful
How to replace cicuit breaker mitsubishi ws 48511
It does not have a circuit breaker but if green light comes on for a few seconds and goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
My Mitsubishi TV has been working fine. Today I pressed the power button and the light came on and then clicked off about two seconds later. What can be done about this?
This will tell you what kind of problem you have:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
sd tech
My 65 in mitsubishi medallion hdtv 1080 wont turn
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
8helpful
I have white and black spots on my 65in hd1080p what is it tv is on 2 years old
Hi, I have a mitsubishi 65" DLP model # 65733 that I bought in December 2007 brand new, about six months ago I started spoting white dots on my screen that started blinking and then became permanent, thinking is was dust I cleaned everything inside with compressed air without success.
The stars multiply daily to a point that it was intolerable to watch anything with all the white stars and a few black ones that showed up.
We called mitsubishi but got no where, I was out of warranty. (they still deny having a problem with their DLP's)
I had a service tech inspect the tv and was told it could run about $800 to $1000 to replace the light engine with refurbished parts with 90 day warranties.
Researching on line I came across a DLP chip that is compatible with several mitsubishi and samsung models, so I decided to chance it, and replace just the DMD chip before we trash the tv, it was unthinkable to pay $800 to repair a tv that we could buy now for under $900.
Thanks God the "gamble" paid out and the problem got solve with just $150 DLP chip in about 15 minutes of my time.
If you are not mechanically nor electronically inclined, I recommend you use a technician for the installation, but don't let anyone tell you you need to replace the whole light engine, it is a ripoff.
If your problem is just white or black dots on the screen that do not move.......this will solve your problem!!
P.S. Hope this will help you and for the record..... "I will never buy a mitsubishi product again".
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL [email protected]
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
2helpful
I was watching tv and the tv cut off and the red lamp light came on does it need a new bulb?
Lamp light lit that means lamp is dead and time to replace it.
If lamp has not been replaced in 2-3 years then its time to replace it. Make sure to buy original lamp for TV safety.
2helpful
2answers
2answers
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
MITSUBISHI CS-35 TV, VERTICAL PROBLEM
1: why have you posted this under Windows XP problems? 2: using entirely uppercase letters in a textual message is considered to represent shouting. Try posting this under a more appropriate category and pleas don't shout at everyone.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
