Drills Logo
Posted on Jul 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hilti TE 17. Hammer doesnt work. Rotary does.
Hilti TE 17. Hammer doesnt work. Rotary does. Any ideas?
Parson's Repair Shop
Level 2:
Sergeant:
  • Expert 284 Answers
  • Posted on Apr 17, 2014
Expert
Level 2:
Sergeant:
Answers
284
Questions
0
Helped
226376
Points
685
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
1 Related Answer
Anonymous
  • 2176 Answers
  • Posted on Mar 06, 2010
SOURCE: hi i have a hilti te 12s hammer drill. the rotary
go to Hilti.com or call them direct at 1-800-879-8000, the only place I know to get parts from is Hilti. Please let me know if you need more assistance.
My hilti te 805 runs but no hammer action
According to the operating instructions for the Hilti TE 6-A22, if the rotary hammer is running but there is no hammering action, it could be because the rotary hammer is too cold. To fix this, bring the tip of the drill bit into contact with the working surface, switch the rotary hammer on and allow it to run. If necessary, repeat the procedure until the hammering mechanism begins to operate. Also, ensure that the function selector switch is set to "Drilling without hammering" .
If this doesn't work, you may need to take your tool to a professional repair service. You can find a list of authorized Hilti service centers on their website.
The chuck on my Hilti TE 24 hammer drill keeps falling off. I doesnt appear to be anything broken. Either there is a missing snap ring or I am just not putting it back on correctly. Any suggestions?
the header list 2 different drills, if yur chuck has a colllar with a quick release, I would suggest thoroughly cleaning and then using a lubricant, usually there are steel balls that lock into detents in the spindle and they might be stuck the collar should move freely.
Hilti te 15-c i have a oil leak behind the chuck.
It depends on where the leak is. if you email me I can send you an exploded diagram of tis machine. This will give you an idea of how to take it apart.
[email protected]
9helpful
2answers
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
1helpful
2answers
NEED PARTS FOR HILTI TE 17
hi i have a 30 year old hilti te17, yes i know but its great but i need the bit holder ( chuck i think its called, the thing that hold the drill bit in for this hammer drill, otherwise its works perfect, built to lasst these things, but parts are hard to come by in aystralia, anyone help me if you can please
lulu
6helpful
2answers
Grease for hilti te 24
any liquidy grease like lubriplate or milwaukee type Y grease part no. 49-08-5270
1helpful
Te-5 rotary hammer i need parts
Call Hilti direct at 1-800-879-8000 and speak to them. They can fax or ssend you a breakdown of the tool list. They will also sell you parts. I don't know of an outside source for Hilti parts. If I have helped you would you please rate my response accordingly and Thank you.
2answers
Hilti TE-5 does not drill
Check the motor if the motor has power and then the gears are not working. If the motor doesnt have any power then you need to check for power. To get at the gears you are going to need to remove the chuck
Top Hilti Drills Experts
Paul Bade
Ngoro
john h
Are you a Hilti Drill Expert? Answer questions, earn points and help others
