Dell Inspiron E1505 Notebook Logo
Posted on Apr 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Roxio media manager install
I am experiencing a problem with a roxio media manager install. It keeps trying to locate file. I cannot get it to stop or delete as I do not use this particular program. It also prevents a shut down I have to do a hard shut down.
  • Anonymous May 11, 2010
    shall we assume it's the proper operating system version?
Anonymous
Level 3:
Genius:
  • Master 1,027 Answers
  • Posted on May 09, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1027
Questions
0
Helped
641819
Points
2823
If you go to start menu and run, type in msconfig.
Go to the startup tab and uncheck the items you don't want loading up - roxwatch9.exe is one (whether or not there's a separate entry for media manager I can't recall).
Reboot, tell the nag screen please go away and don't bother me again.
In roxio 10 suite when I start the classic view for a data burn ..Roxio start trying to install the update manager. A total pain.
open your task manager find the process that is trying to update, remember the name, stop the process and then search for it in your c:\ directory and delete it maybe that will work
1helpful
I can open itunes and an error keeps poping up" roxio media manager" unable to find certificate file HELP
Here are some steps you can take to resolve your problem.
1. Download, install and run "Ccleaner"; a handy little temp file and registry cleaner/organizer. On many occassions, after running it, goofy messages disappear having been a result of faulty registry entries or deletions built up over time.
http://download.cnet.com/ccleaner/
2. Open Roxio and go to help> updates, and download and install any updates that are available.
3. Open iTunes and go to help. updates and do the same.
4. If you still see the message at this point, go to the control panel> programs, and uninstall Roxio. After restarting your computer, the message should be gone for sure. If you have the install disc for Roxio that came with your Dell, simply re-install it. If not, use Media Player to do your burning with, or any other of a vast number of free DVD/CD burners that can be easily downloaded and installed.
Good Luck
1helpful
2answers
Internal error 2718 roxio media manager pops up upon startup. I have deleted everything in the registry relating to it. i have used reg cure, system mechanic. I cant open system restore, user accounts or...
Make sure you are logged in to an account with administrator privileges.
Click Start, click Run, type "msconfig", click OK. In System Configuration, click the Startup tab. Uncheck anything relating to Roxio Media Manager. Click OK and reboot.
Be very careful when dealing with the registry. Most registry cleaners do more harm than good if not used carefully. The "Delete everything I find" attitude often leads to a slower computer than when you started.
2answers
There is a program called Roxie Media manager that keeps trying to install itself when i turn on my computer. Windows installer keeps trying to install it no-matter how many times I try to cancel it. ...
Well you can Install the "windows installer cleanup utility" run it and delete the entry for Roxio, please follow the below link -
http://support.microsoft.com/kb/290301
Just run the software after downloading . follow the below link to direct download -
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
Post further comments for more help or information.......
Good Luck!!
Thanks
I have lost my Roxio install disc and I think I have deleted an application in error. Although it still works perfectly every time I boot up or move any file or photo on my PC it keeps trying to install...
Start -> Control Panel -> Add/Remove Programs
and remove ROXIO.
Then, access http://www.MajorGeeks.com
and download "AShampoo V6 Burning Free Edition" and install it.
Great software, and Version 9 (which is not "free") is even better.
Roxio Media Manager Keeps Trying to Install
the Roxio Media Manager is belong to the system, and this part the program is in need to run part of the system...
1helpful
How do you delete media files?
you can download the blackberry desktop manager with media manager, which is Roxio.
you can delete and add music videos etc.
when your done with the deleting part, disconnect from the desktop manager.
remove your battery and replace it in the phone, let your phone reboot and you will not have those songs anymore.
you can get the software here: http://na.blackberry.com/eng/services/desktop/
Good Luck and Thanks for using FixYa
Every time i turn on windows the roxio media manager keeps loading and does not turn off. how do i get ride of it
Once the system is booted up click the start button on the taskbar, click run, type msconfig in the box and enter. That gets you into the startup files where you can remove Roxio from the startup. That does not delete Roxio from the system, it just stops it from opening at startup. If Roxio starts upon start after that, then there is some application starting that requires Roxio, and you will need to address that issue. That rogue application should also be visible in the startup list so you can remove it thereby fixing the issue. Be sure to save the settings.
1helpful
Removing Roxio media manager
You can try to download revouninstaller or ccleaner, to uninstall the programs.
1helpful
Certificate File is missing in roxio
The following steps will completely remove any Roxio and Sonic software from your computer.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
