IF it is a THERMAL printer, they usually use special Thermal paper . It burns the image onto the paper with a thermal print head.
There is NO ink to change
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
You might want to try just resetting your printer rather than changing the ink pad. The warning is based on a count of how much printing is done, not a measure of full the ink pad has become. Consequences of not changing the ink pad, if truly filled to capacity, could be ink leaking from the bottom of the printer.
The following video show how to perform a reset that should work for your printer. The second video will give you an appreciation for how to change an ink pad and help you to decise whether you wish to attempt.
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/0/70744652a954e650c1256f820078e0a2/$FILE/MC24x0-Replace%20Toner%20Cartridge.pdf Goto the above link and it shows the PDF doc. for changing the cartrides.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
