Before you run the ROM Update Utility (RUU), make sure you have done the following:
Backed up the data on your device.
Standby or hibernation mode of your PC has been disabled.
Close all running applications on the PC.
Set aside approximately 25 minutes to allow the device to update.
Charged the battery to at least 30%.
Download HTC Sync for Android.
Install the HTC Sync software on your PC if it is not already installed. This software was included in your HTC Hero gift box. The minimum required HTC Sync version is 2.0.28. We have HTC Sync for Android 2.0.40 available for download; newer versions might be available from www.htc.com.
If the HTC Sync application appears on the screen of your PC, you may simply dismiss the wizard by pressing the Cancel button.
Run the Hero 2.1 MR Upgrade RUU file.
Follow the on-screen prompts to install the update for your HTC Hero
WARNING: During the upgrade process, do not attempt to make/receive calls, press any buttons on your device or disconnect the device from the USB cable as this will stop the update and your device may be rendered inoperable!
If you have a problem with the connection between your device and PC be sure to check the connection type in your device. This can be done in the device via Settings -> Connect to PC. Ensure that HTC Sync is selected.
Intro :
This quide will help you setup you phone as a wireless router. I tested this on HTC hero A6262(
Firmware : 2.1 , Villain 3.1 ROM) You
will need :
1. An android device with root access.
2. Mobile Network Connection
3. Wifi Tether/ aNetShare application in the phone. Intructions :
1. Enable the mobile network from setting.
2. Open the Wifi Tether/ aNetShare app in your phone, and tap “Start
tethering”.
3. Go to PC/Laptop and search for wireless networks, you will see you
phone’s SSID.
4. Click connect.
5. Once connected open firefox.
6. Go to Tools > Options > Advanced Tab > Settings.
7. Select Manual proxy configuration and enter the proxy setting.
8. Click Ok.
9. Enjoy !!
Yes, it does have Android. The first version has 1.5, and then recently, the Hero can be updated to version 2.1. It will probably not be getting the official release of version 2.2.
only if you carrier is putting one out. Other wise you need root access (unlock the phone) and try one of the MANY ROM upgrades on the net. Beware that not all "upgrades" will be benign. Lots of malware out there.
Unfortunately you will need to upgrade your flash player,there's no way around it if u want to watch videos online.
However you could try downloading the opera mini browser,its free and it generally incorporates the latest version of the flash player.It should allow you to watch virtually any video.
Hope it helps
First off, the version of Flash on the Hero is a stripped-down version. You will not be able to get full-functioning Flash for your phone. That means that a lot of Flash content will not work.
Another thing to check is within the Browser settings. When in your Browser, hit Menu > More > Settings and scroll down and see if Enable plugins is checked off. Turn it on and it will turn on the Flash Light for your phone.
But again, not true Flash on the Hero. They might be coming out with a full version of Flash sometime. I have heard there is something coming.
