I was just given a used Keurig B40, and the previous owner said that it no longer worked. I descaled it and no water went from the reservoir to the unit and nothing came out (obviously). I tried over and over and finally water pored out with a lot of sediment. After a few cups like this it clogged again. When I run it, the unit knocks and whirs and a few drips go into the cup. Is there any way to release the water from inside the unit or to clean out the mineral residue? If not, do you have any suggestions on how to fix it?
We live in an area with rather mineralized water. and have had regular issues with this. the best solution we ever had to this sort of problem was to simply descale with a vinegar mix until it ran clean and then go with very regular descaling 9 in our case 2 a week, unitl the dog chewed through the cable). I had my B40 for almost 3 years. Good luck!
SOURCE: how do you descale the keurig B40
use descaling product not vinegar ,vinegar remove calcium in little piece descaler melt calcium 1 part descaler 1 part water fill water container start machine for a few second turn off let it seat for 15 minute repeat untill empty to reset the lightnormally its maneer of pressing the on button
i get back to you on that one pierre
SOURCE: Need a replacement gasket for the water reservoir for Keurig B40
I would suggest you contact the company directly for advice on where to get that part or possibly they will be able to supply it to you directly.
Robert
SOURCE: my B40 says ready to go then when i push button to
use some CLR or bleach water in it to clean it its clogged with calcium
SOURCE: I'm having a flow problem with my keurig brewer.
you will need to give it a vinegar flush..white vinegar..I put about 1/2 cup with a full tank of water..keep running the water until empty..then run thru a full load of clean water..then taste some of the hot water..to see if the taste is gone....
you do not need to use k-cups for this
SOURCE: b40 makes only half
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Yes, it may take more then one time...
Check out this tip about how to
descale your Keurig coffee brewer
How
to Descale your Keurig Coffee Brewer
heatman101
