It means the battery is broke :( had the same problem with two of mine, i took them apart and found two damaged cells in both, so managed to make one out of two so to speck. Problem is the pcb is telling the charger the bat is broke, seems you only get 2 goes when it flashes red/green something i didnt know,
So if you do manage to fix/replace the cells you'll probably end up with the same problem i've got now!
I've looked about but no one seems to know or everyone is keeping it to thereselves, but im sure there must be away.
I'm not sure if this helps you but just saying wot will happen next if you replace the damaged cells there are 10 in total 4volts each
Good luck
SOURCE: when put on charge the green and red light flash
that usually indicates a bad battery. I would unplug the charger for a couple minutes to reset it and then try again before looking at replacing the battery. Most shops have a tester there that can tell if it is in fact bad.
