Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD750 and SD1000.
Resetting Settings to Their Default Values - PowerShot SD750 and SD1000.
1. Turn on the camera and press the <MENU> button to open the menu.
2. Using the button, highlight the yellow (Set up) tab. My canon ixus70 will not - sd750resetscreen.gifimages/sd750resetscreen.gif" alt="sd750resetscreen.gif" class=My canon ixus70 will not - arrowdownbutton.gifUsing the button, select [Reset All..] and press .
4. Select [OK] and press .
The sd500 is reset in the following way:
Solution: Procedure for resetting the camera to default PowerShot SD500
Resetting the Settings to Default
You can reset all of the menu and button operation settings to default except for [Date/Time], [Language], and [Video System].
1. Turn on the camera.
2. Press and hold the <MENU> button for longer than 5 seconds.
The message Reset settings to default? appears on the LCD monitor.
3. Select [OK] using the and buttons, then press the <FUNC./SET> button.The screen below appears while resetting. The normal screen resumes when resetting is complete.
To cancel resetting, select [Cancel] instead of [OK].
Settings cannot be reset when the camera is connected to a computer, to an optional direct print function compatible printer (CP series) or to a direct print function compatible BJ printer (optional).
The following cannot be reset:
Shooting mode
The Date/Time, Language and Video System options in the (Set up) menu.
White balance data recorded with the custom white balance function.
Colors specified in the Color Accent or Color Swap modes of My Colors.
Newly added My Camera settings.
