Garden Logo
Posted on Jul 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Karcher hds 555c user manual or assembly guide
Sir, I'm looking for user manual or assembly guide for Karcher hds 555s ; Could you pls help? [email protected]
David Hill
Level 2:
Habit-Forming:
Scholar:
  • Expert 103 Answers
  • Posted on Jul 12, 2019
David Hill
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
103
Questions
Helped
38052
Points
366
Try mymanuals.net. It usually costs approximatly £1.90
matt
Level 3:
  • Karcher Master 1,666 Answers
matt
Karcher Master
Level 3:
Answers
1666
Questions
Helped
696155
Points
9998
2 Related Answers
Anonymous
  • Posted on Nov 07, 2008
SOURCE: karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is [email protected]
Cheers Matt.
Anonymous
  • Posted on Jan 08, 2009
SOURCE: KARCHER HDS 1000 de
hi jim i have the same unit diesel burner and diesel engine have you tryed a new accelorater cable?
Karcher HDS550c Service Manual please.
It will be like this, HDS Compact Series. Page 27. They are unmistakable, a silver aluminium can with wires coming out of the end.
https://karcher-marine.com/wp/wp-content/uploads/Downloads/12722010/Service%20manual-SMA-5290965-002-00.pdf
Hi Looking to see if anyone has a wiring diagram for a karcher hds745 o.eltro pressure washer any help would be much appreciated. even pics of electrics would do.
Not sure what the 'o.eltro' means? There is help in the link and the service manual for a different series of HDS washers. You could also contact Karcher direct.
https://www.google.com/search?q=karcher+hds+745+wiring+diagram
2answers
My Karcher 601 HDS Pressure Washer does not pump water.
Question edited for clarity.
Question moved from Washing Machines to Karcher Pressure Washer.
Probably a broken impeller. Strip down, service and replace o-ring seals.
https://www.google.com/search?q=karcher+hds+601+c+no+pressure
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
