www.fixya.com/.../t15635769-main_bearing_bolts_torque_suzuki_xl7_... Jan 2, 2013 - Main Bearing Bolts Torque Suzuki XL7 2.7 2003 - Suzuki 2002 XL-7 ...What are the torque specs for cam caps on a 2005 Suzuki forenza 2.0 ... Need torque specs for 1.3 liter motor,connecting rod bearing and main bearings.
main bearings torque is 18 ft lbs. plus 90 - 94 degrees, rod bearings torque is 13 - 16 ft lbs. plus 90 - 94 degrees.crankshaft damper bolt torque 80 - 94 ft lbs, fly wheel bolts torques 94 - 101 ft lbs.
I'm sending you the torque specifications for your main bearings and also your head bolts. I also sent you main bearing and cylinder head tightening sequence. I hope this will be useful
Main Bearings Torque specs. 40-43 Ft. Lbs.
Cylinder Head Torque specs. 56-60 Ft. Lbs.
