Question about Beko DSV64W White Vented Tumble Dryer 6 kg, 9 Cycles
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
  • 6 more comments
  • dea35 May 03, 2008
    Hiya, i'm really mad at the moment. My tumble dryer DRCS 68 which is only 4 months old, has suddenly stopped heating up. It is still spining, but is giving off no heat whatsoever. Please Help!!!!!
  • Anonymous May 27, 2008
    same problem a beko thumble dryer DRCS68W SPINNIG BUT NOT HEATING????
  • Anonymous Jun 03, 2008
    I have exactly the same problem, spins etc but no heat, machine is just out of warranty but has been hardly used.Repairers don,t seem to want to work on Beko,s as they say spares are very difficult to obtain. Hopefully someone will come up with the answer before I have to contact Beko and end up wiyh a big bill!
  • Louise2268 Jun 09, 2008
    I have the same promlem with this model DRCS68W. Have tried all the steps in the manual to try and fix it but still the same. drum working but no heat at all. just over a year old and out of warranty!!
  • sharon jones
    sharon jones Mar 21, 2014
    Hi ive just hit the same problem tumble is still working but not drying the clothes... Any ideas??
  • sharon jones
    Hi can anyone help, ive just got the same problem.. Tumble is still working but not drying the clothes?? Any ideas??
  • bob pearce
    bob pearce May 01, 2014
    claim under warranty - contact beko
  • Debbz Hughes Jan 08, 2019
    Is there a reset button for model DC7110W
Is there a reset button on a beko tumble dryer drvs 62 w pls
Posted on May 14, 2009
  • Paul Bickerton
    Paul Bickerton Aug 02, 2014
    yep its behind the back pannel
Go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Posted on Aug 20, 2008
  • 4 more comments
  • murppy Jan 29, 2011
    helped me a lital thank you
  • Kaz120 Jul 13, 2011
    Have tried doing this but lights dont flash after holding button for 10 secs
    Have just managed to get all lights to flash i had to hold down both cancel buttons first then realease them its going through its test mode now will update later to let you know if it has worked
    Have tried doing this its still the same no heat at all
  • connolly1974
    connolly1974 Nov 25, 2012
    This just worked for me Thanks
  • Jayne Tear
    Jayne Tear Jun 30, 2017
    Thank you so much for this. I was just about to start taking dryer apart to reset thermostat and saw this solution. I gave it a try (not hoping for much) - it worked - what a simple solution can't thank you enough. You would have thought this would be mentioned in the fault finding part of the user manual.
How do i change the thermostat on the beko drcs68w
Posted on Feb 16, 2011
Where is the cancel button.
I have tried
setting the dial to delicates then turning on the machine. Pressing down the start/pause/cancel button for 10 sec then release. Press the start/pause/cancel again but not all lights show the machine just starts its normal cycle.
I cant seem to get all lights to flash and get the machine in test mode.
Any further assistance would be a great help.
Those buggers at beko dont even supply real online help or manuals.
Posted on Sep 21, 2008
    New Friend:
Turned the dial to delicates hold down the buzzer cancel button (one on left) and turn on machine. After a few seconds the lights flash and the buzzer goes off. This is all very well but problem of 'no heat' remains so I'm putting it down to a dead heater (about £40+fit).
Posted on Jan 08, 2010
  • 4 more comments
  • Amquietone Nov 21, 2010
    If I am reading embjon correctly, it is not the buzzer button that you should be pressing, but the start/pause/cancel to the right of the buzzer button.
    Has anyone had success in doing this to reset this machine? And having the heat work?
  • matt leech Nov 02, 2012
    i tried this,nothing happened and cant turn the machine on now
  • Luke Rollason Nov 02, 2012
    When this dryer goes haywire the reset works fine. If there's no heat you will need to change the heater which is really easy to do. Buy a new heater:http://www.amazon.co.uk/GENUINE-BEKO-Tum...
    Turn off power, unscrew back and swap the heater, screw cover back on and there you go. I've been through 4 heaters with this dryer and each time it's been due to operating in low temperatures of around zero or below. As my dryer is in the garage it's got extremely cold each time the heater has broke. Coincidence I think not.
  • Julie Cooper Dec 18, 2012
    I have two of the sensor dryers and both stopped heating when the weather gets cold as with Luke's. So annoying as in the manual it says that they need an operating temp of 5 degrees but that information is not available when purchasing. There should be a warning as most people have dryers in a garage or utility area. Electricity is expensive enough without having to heat the room for a dryer!
  • Paula Miller Nov 28, 2016
    Tried the reset. Still not drying. Cleaned the condenser out. Still no joy. You can hear the machine working and the clothes get warm but won't dry them. Any ideas?
  • Peter Collins
    Peter Collins Jan 31, 2017
    I had the heater element broken on mine, I replaced them for £17 from ebay. I did it myself. it worked fine afterward,, but now I have the same issue of no heat. the elements look fine, but maybe the thermostat or control circuit is faulty, I dont see why they would stop heaters if the room was under 5 degrees, my unit is in the shed, and probably around that temp.
    New Friend:
My tumble dryer wont heat up either, when i turn off machin and hold down cancel button then turn machine on all the lights flashes but then when i press start button it make a loud buzzing noise and still no heat.. can any1 help me asap please...
Posted on May 03, 2012
  • 3 more comments
  • Richard Tudway May 04, 2012
    Mine did the same again since Dec 14th and I had to clean the heat exchanger again. With the wet weather my better half uses tumble dryer a lot as we have 3 kids. The heat exchanger needs cleaning regulary. Mine works fine after. If not the tumble dryer go's through all the motions except drying clothers.
    what is the heat exchanger?
    its a beko drcs68w, i changed the belt now theres no heat
  • mburridge
    mburridge Jan 03, 2013
    The heat exchanger is located on the front bottom right. The cover just pulls off and you will see a sign saying heat exchanger clean monthly. Then there are 3 grey latches and a red latch. Turn these and you can then pull the heat exchanger out. Clean both sides with a brush so that air can pass through. I did this and now I have heat again
  • Theodore Gadget Jan 16, 2013
    Tried all previous tips - with no joy - but saw this & sure enough the heat exchanger was totally blocked. Didn't know the madre ******** was there! Thanks a bunch mburridge - yr a star - take a formal blessing from a ham ****** diy er!
    New Friend:
My tumble dryer is making a rerrible noise
Posted on Mar 29, 2011
    New Friend:
Unscrew back cover and press reset button on the bottom thermostat directly above heating elements (the one with the blue wire running to it). It will have likely tripped due to opening the door during the cycle (fan turns off while heater keeps going for a while) or due to blocked filters. If this does not work ( you'll hear a click when pressing the reset button only if it has indeed tripped) then the thermostat is likely broken and you will need a new element and thermostat set. Easy to fit if you do need to.
Posted on May 13, 2014
  • rikki
    rikki Feb 22, 2015
    didn't click but seems to have done the job . Thanks
  • Kenny Jester Mcauley Nov 03, 2015
    dude you where right did the trick would never have known that and would have bought a new one
    SO A HUGH THANK YOU
    New Friend:
I cleaned the heat exchanger really well (Like I shold do monthly, but don't) and mine now works!
Posted on Dec 14, 2011
    Top Expert:
  • Beko Master
  • 6,289 Answers
Check heating element first.
Posted on Jan 08, 2019
6ya staff
SOURCE:
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
    check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
    Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
    Beko DRVS 62 W Tumble Dryer Squeakig
    I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
    Feb 11, 2014 | Dryers
    Instuctions for BEKO DRCS68W required
    Good morning, afternoon, evening or night; whatever time day you are viewing this solution post. Thank you for choosing FixYa to assist you with your request. You are requesting an owner's manual for the BEKO DRCS68W Tumble Dryer. Below is the link you can click on to retrieve your manual.
    http://www.beko.co.uk/manuals/DRCS68.pdf
    Thank you for choosing FixYa as your one-stop solution spot for assistance with questions, problems, concerns and requests with products. We hope that you visit our website again the next time you need assistance. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
    May 28, 2011 | Audio Players & Recorders
    My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
    Looks daunting to start with but just done mine,
    remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
    Feb 07, 2011 | Dryers
    Beko DRCS68 condensor dryer is making loud vibration noises
    hi there......when you replaced the drive belt you most likley disturbed the drum on its bearing seats (small plastic curved units) or indeed knocked 1 out altogeathrer...this would account for the loud bearing or metallic sound...it may also be the rear bearing these tend to eventually rund dry and fail..
    regards Sir GalAHAD
    Apr 17, 2009 | Frigidaire GLER331A Electric Dryer
    Tumble dryer drum only starts when i start it first by hand
    starter capacitor went bad on motor... replace
    Mar 12, 2009 | Dryers
    Beko DSV64W White Vented Tumble Dryer 6 kg, 9 Cycles Logo
    34,189 people viewed this question
    Top Beko Dryers Experts
    Marvin
    Marvin
    janman
    Lawrence Oravetz
    Are you a Beko Dryer Expert? Answer questions, earn points and help others
