Based on your post/description, I will assume that you would want to connect a PC to a Projector.
For a 3M DY-0205-1002-9, pls contact:
3M Customer Information Center
Hale Avenue Business Center
3M bldg. 506, POCS Destination Code 0444
835 Hale Ave. North
Oakdale, MN 55128 Fax: 651-736-6320
or try
3M Visual Systems
1-800-328-1371
(Fax) 512-984-5105
Internet: www.3m.com/presentation
Email: OHP -
[email protected] EPS -
[email protected]Should you opt for a replacement, you may want to consider
DVI
to VGA Analog Video Cable or similar products.
Alternately, you can use a converter box that will accept VGA inputs but whose output is DVI-D compatible. A fine example is
VGA to DVI Converter/Scaler but of course any comparable brand/model should also work.
Hope that these be of help/idea. Pls post back how things work out or should you need further information.
Good luck and kind regards.
