Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Contact Delta at 800-345-3358 and ask for replacement parts. With the lifetime warranty Delta customer service was awesome and sent out parts I needed to fix this same faucet.
To fix the leak in delta faucet is have a repair kit for Delta 470-WHRS. The repair kit consist of O-rings replacement. Otherwise, you have to buy a replacement for your Delta 470-WHRS.
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
