Yes you can load your memory stick to any laptop and get it downloaded. Most of the present day has a memory slot and you will be able to retrieve the data from the memory stick. If the slot does not accept then use an adapter. I hope you can try this out with the help of any friend who has one such device. Hope this helps. Good day
SOURCE: Reinsert the memory stick...
you will need to re formatt the card and this problem should be solved
SOURCE: Sony cyber shot DSC S930 "Reinsert Memory Stick"?
I am having the exact same problem and I have only had my camera for 2 weeks. We took it on vacation and I really want my pictures. Did you find a solution? Was it the memory card or ther camera?
SOURCE: getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
SOURCE: Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
